Did you check/adjust clearance for both valves?
Originally Posted by
ro347
Im in need of help with my Saito 100. Recently I replaced gaskets and seals, and ever since I haven't been able to get it to run right. IF it wasnt one thing it was another. Once Ive ruled everything else out, Ive come to the conclusion I had a timing problem despite know how to set it during reassembly.
With that said, last night I took the engine apart ( which is when I realized timing issue) and saw this SEE PIC.... Looks like the valve hit the piston at some point. Everything looked ok otherwise, so I reassembled and tried to run. Seem to do ok put had a hard time with the high end needle and engine lost compression again.
So to my point - IS THERE ANYONE WILLING TO HELP ME GET THIS THING GOING AGAIN>>>> PLEASE!!!!!!!! Im just at a lost. Im guessing maybe replacing the valves (as one might possible be slightly bent) might help, but dont want to be throwing money into parts Im unsure I need.
Would appreciate if anyone could give me the rundown of what to look for and check.
