RCU Forums - View Single Post - Demon Cortex Gyro question
Old 09-02-2014 | 09:33 PM
siclick33
Originally Posted by jws_aces
I have 2 servos on the elevator. I just finished setting it up. I am going to use the knob to adjust the gain for the first flights. I have the travel set to off then to normal mode. I adjusted the travel so the hold side will not work. I lower it to 0 on that side of the travel for the channel I have the gain plugged into.
Any suggestions on first flights?
20-30% gain in normal mode should be ok for starters but you're always better off starting low and working your way up. I might be also tempted to have a switch to turn the gyro off for the first flights in case you knock the gain knob or something else happens; that way you can instantly turn the gyro off if you need to.
