@Agustus1967, aka, gus, If you mean the Elefant, the fit of the plastic parts is good, but like all models may need some clean up. The running gear is where the work will be. I have not had a chance to test fit the parts to see if this is a newer kit or first production kit. That said the first production kits had fit issues with the running gear which required some test fitting and sanding to get them right. Some on this site even replaced the running gear with the Asitam metal replacement parts. I will try the plastic parts first and at some point move to metal tracks and road wheels.
