Originally Posted by
HotelSierra
Question about turning off the gyro in flight. Will there be a problem turning it back on during the flight, since the gyro needs to be "stabilized" - on the ground not moving to calibrate it before each flight?
You are correct. Unit can't be turned off (there is no way to do it).
Gain can be made zero, though.
