Originally Posted by
jjkirby
Those with the DLE motors installed, how did you setup your throttle and choke linkages. From looking at the manual it seems like the fuel tank is in the way for the throttle. Setups and pics would be great thanks!!!
As Al said, you can move the fuel tank waaaay back. I used a separate servo for choke because of the narrow cowl. Also, I strongly recommend adding a 1/8" balsa doubler to the wing saddle. The photos are pretty self explanatory.
Good luck!
Al
