RCU Forums - View Single Post - Converting an HL Panther "G" into a late "A"
Thread
09-08-2014 | 01:44 PM
1
dgsselkirk
Oct 2013
721
Greetings All!
If you are a rivet counter don't bother reading any further...
It will be an O.K. conversion from scale drawings and some other references but not a balls accurate conversion by any means...
If you are a modder of medium or lower skills like me, you may be interested in doing this to a G just to have something different on the field. I have looked at a few of the guys who have done this conversion. There are a couple out there but I decided to go my own way and build a late "A" with zim. there is a kit out there as well but as usual I will be keeping the cost down and utilizing as much of the original vehicle as possible. The only real upgrades are a clark board, gearboxes, speakers, and the zim kit because having worked with the Atak kit on my L70 it made it look so good and was so easy to work with I have decided any zim builds in the future that is the way to go!
So first, I had 2 Panthers. One I bought from MichaelC which already had the black gearboxes and Clark board in it as well as the servo recoil and high viz flash put in. The Second G is stock from Matomart with metal upgrades and this is the one I decided to do in an "A". Michael's will be converted to an early "G" with zim after this one is done.
Now, originally my plan was to simply build 2 "G"'s regular and go with that . So to that end I went ahead and gutted them and did my usual resin base in the bottom.
panther 2.jpg (80.91 KiB) Viewed 22 times
panther 3.jpg (55.94 KiB) Viewed 22 times
panther 4.jpg (62.22 KiB) Viewed 22 times
panther 6.jpg (29.59 KiB) Viewed 22 times
panther 7.jpg (47.41 KiB) Viewed 22 times
panther 8.jpg (60.36 KiB) Viewed 22 times
As you can see I was doing both hulls at once. Once I did the lowers last spring I had work to do for some other guys so they went on the shelf. During that time I changed my mind and decided to do the 2 different models. You will see only the "A" from here on in. I will start posting these tonight...
Reply
Like
dgsselkirk
View Public Profile
Send a private message to dgsselkirk
Find More Posts by dgsselkirk
View iTrader Profile
