Originally Posted by
mikes68charger
Hey guys it took some time but Im almost 100 leak free only the air brake on the back leaks when in the up position. If I could take it apart I could put a little o ring in there to limit its throw 2mm or so and all would be great
Where is NEUTRAL for the elevators?
Any elevator changes needed with full flaps?
Hopefully mine will be test flown at the weekend, I will try and help out if I can.
Yes it took me a long time to find all the leaks, some in the 4 ways and some in the the cylinders, I replaced some but not all.
Elevators are set up to be flush with the tips of the speed brake.... for now anyway, I have set the c of g at 200mm now for the first flight and see how it goes. Lots of reading on the C of G, so doing the average of every ones answers....
