I'd appreciate it. I've messed with it and it really doesn't seem right.
I just got the backplate off without too much difficulty. Nice and clean and oily inside. I put a nice big prop on it and took out the plug. Put in lots of oil and will turn it over some more tonight.
These are just regular turbo plugs, right? I have some NovaRossi turbos so as long as I get the same heat range they'll work or no? Has anyone tried any other plugs? If you're using only Norvel plugs where are you getting them?
