Originally Posted by
rchobbymodels
HI Scott, they told me that the F100 batch for this year is done and wings are closed so can not take pictures but I had an old picture of the stab though..:The locking mechanism is a clamp and a anti-rotation pin that goes into the shaft's slot, as you can see in the pictures below:
Guys, the stab mechanism mounted on the bulkhead seems to be the exact same system used successfully for years on the Tam Super Hornet. However, the Tam control mechanism was mounted to a solid plywood bulkhead. This bulkhead seems to be some sort of HC or or foam sandwiched material. I would warn about eventual compression and loosening of the attachment bolts We had it occur overtime with the Hornets.
David S
