Originally Posted by
Panther F
What sprockets fit on these axles?
Jeff
Since the output shafts are the same across all tanks it should technically "fit" all drive wheels. The problem is the shaft length, this one I just got in is 48mm long, which means it is the short shaft version gearboxes. In the next day or two I will install them in every tank we have and let you know which ones they are 100% in or which ones if any need modifications. Which tank are you trying to fit?
