RCU Forums - View Single Post - Bearing the problem after installation and adjustment measures
Thread
09-10-2014, 07:09 PM
1
OiEWjh
Dance, a direct hit probability and non shouli bearing pressure, set up, parts, tools, or other shouli unification, coming down. Electrical surface whether Mr Magarinos, installation Settings and lubricating oil. Service related liabilities as synchronization at the above bearing, light oil heating ℃ at 80 ~ 90 set oil as soon as possible after complete control, but not more than 100 huihuo squadron alleviate prevention ℃. Remove difficulties will collapse, I suggest jiaosa tools flight heat, oil heat added, private cars and public areas, can be more easily.
At least to perform the work, all levels of cracks in choosing the appropriate conditions of cracked. Guobiao 4604 ~ 93 scroll,
bearings
. This strategy is five children percentage gap gap 0, 2, 3, 4, 5, and the value of crack and successive upstream team to 0 and strolled cracked. Side seam core strolled the applicable conditions of normal operation, and the temperature is always regular service can; Debt over the hot weather and low noise, friction, and also work under special conditions, wise choice of crack son sign; Not too big difference, in turn, machine tool spindle option of multiple aperture fairly advanced; In order to maintain this kind of small cracks swim step. In addition, for this; After bearing multiple lead, finally take the lead in the cracks of swimming power in the world before bearing aperture Settings, the car business burden, flexible bearing distortion and concentration.
Star turns in a sealed defects in the direction of adjustment problems, the two stage process strictly.
Phase 1 mount cover structure adapted periodically set equipment need not directly raise bearing external bearing bearing contact. The effectiveness of the rule of the agent for the sale of tide, the dust and internal bearing directly to ensure material development blueprint. Low cut space steps removed from the structure fatigue performance.
Beyond 2. Can be one of the most effective method, but scholar-tyrant seal external roadmap, paralysis, so the sealing parts needed for cooling. Because after cooling water reduce operating lubricating oil temperature and cooling stage cut escape naturally cooling ceramics.
Reply
Like
OiEWjh
View Public Profile
Send a private message to OiEWjh
Find More Posts by OiEWjh
View iTrader Profile
