Hey Kwik,
Your photo shows no cross ribbing or bracing behind the cooler thingy. Did you remove it...mine has some bracing about 1 inch behind the cooler thingy that goes between the ribs.
jim
Originally Posted by
kwik
That is so sad, and on the second flight.
If you look at this picture, which is from my first Corsair, mine does not have that spar up front;
The design is simply not done by someone with the gray cells in place.
Probably done by someone who can operate some Software Package, but no clue about
Isaac Newton.
I won't fly my second one again, until I have taken drastic steps on that center section.
The 50cc ESM Corsair looks stunning, simply, in my opinion. And that makes it just so much more sad, when it suddenly is just a broken eggshell, filled up with balsa pieces.
