These are prt way thru the fix.
I've made doublers with 6mm ply on the main "spar" Also made a new spar fwd of the main. Applied carbon fibre to the top skin and made carbon fillets with cf rovings. Primarily used Hysol for the ply wood bondings and gap filling.
I run outta Hysol, so I have stopped till my order arrives from DA in Brissy. Then I will apply hysol to the front spar wing skin. Once cured I will attatch the bottom skin with hysol, once cured I'm gonna fill the front voids with expanding foam. I forgot to say I will also make some doublers for all the ribs I can get to.
These pics are the job about half done. Already it has made a marked difference.
