RCU Forums - View Single Post - PITTS 40 - KYOSHO
Old 10-08-2003 | 06:10 AM
polstery
Default RE: PITTS 40 - KYOSHO
I have one, just got it last month the covering is fine, I used standard servos in the wing and yes the servo hole are cut out. If you use smaller servos you will not need to put the little servo cap they supply on because the sevo will not be sticking out of the top of the bottom wing. I have a satio 72 on mine she is fast and will tumble with the best of them..
