Originally Posted by
Sport_Pilot
I was not distraught, you and others went ape when I pointed out that in engineering and per dictionaries, and per english language rules and syntax the word simply means an imaginary line sighted visually. As such it does not mean you actually see anything, or that you have any limit on distance, such as say a star. The AMA defines if for their use, Congress did not.
Right, it is obvious that congress got the definition from the AMA but I can't figure out the source. I was curious since the only source I have found was in the AMA FPV doc 550 which would imply congressional awareness and approval. Thus, negating the FAA stance on VLOS. And you still seem awfully distraught to me.
