RCU Forums - View Single Post - When excited.... take a step back...
Old 10-08-2003 | 06:28 AM
gus
Default When excited.... take a step back...
When sunset's at 6:45, and you arrive at the field at 5:30, and it takes you 20 minutes to set up your just-completed ultrasport kit, 20 minutes to follow the OS.46fx Enging Run-in, another 30 minutes to adjust the idle needle (5 were needed to cut the cowl a bit to get access, 10 minutes to re-check all the controls, screws, etc. Then it is time to go home....
instead, I thought I could see just fine. Nuff said. 45second maiden flight. Re-kitted.
gus
