I was just going to Say. With your connections. You could get the Parts you Need! Just put Battery's in each Wing Near the Center Between 1 and 2 ribs. Just might offset Motor weight some? Cut Ribs so they can Slide Over a Blade with Hole in Wing & Blade for a Pin to hold it on? I have No Shop and No Parts and That is a Set Back! Really Need Real Helicopter Controls at Hub!
