RCU Forums - View Single Post - Question about Stall Turn, Quarter Roll Up and Down
Old 09-16-2014 | 11:25 AM
n233w
Originally Posted by big_G
You CAN do it either way, but if you do the stall turn into the wind, you will find it easier to return along the vertical entry line easier...on center.
...because when you're going up on the vertical you are crabbing into the wind already, and reduces the number of degrees to reverse course. If you stall away from the wind, you will find your plane blown downwind and your downline will not be on center, plus the turn will more than 1.5 wingspan, resulting, I believe, in a major downgrade.
I'm sure you've already noticed how much easier it is to do a stall turn into the wind as opposed to when the air is calm... stalling away from the wind is doubly hard...
