How and where would you add light to a scale model?
Standard International requirements are for a Red light on the Left wing tip, a Green light ont he Right wing tip (I can only remember this by "right IS NOT red") and a white light pointing aft in the tail. The tip lights must be visible from straight on the front to 120 degrees aft on each side. The white light is visible 60 degrees either side of aft. These Navigation lights DO NOT BLINK on a civilian aircraft! In addition a blinking (strobe, blink, or rotating) red light must be on the aircraft some where.
The rest and type of lights depends on what you're modeling.
What kind of lights do you need?
and how would i fit them on or into the plane?
See the ram line of lights at
http://www2.towerhobbies.com/cgi-bin/wti0002p?&M=RAM
