I am using 2 A123 batteries for the Rx fed into a Powerbox sensor switch. The output at 5.9 v is fine for the electronic valves which work very well. Initially i was a bit sceptical about the thin airlines, but they work, no need to change them. Because I was using 20kg cm servos i added a Evojet Powerjack.
John
