Originally Posted by
Lifer
There is no risk in charging the LIFE batteries within the model. You might consider LIFE for the ignition as well. Check the input voltage for your ignition and see if 6.6 volts is acceptable.
It says in the manual that you need a regulator for that high voltage.
