RCU Forums - View Single Post - 140 rx trouble
Thread: 140 rx trouble
Old 09-19-2014 | 09:02 AM
ddennison
My Feedback: (15)
Hi Tom, thanks for the words of encouragement. I will also run mine a little on the gentle side to limit to <25 lbs per turbine.
I have to check on the auto baron/temp mode. I am not sure I had that active or not, but, I had to abort my first take off as the turbine was NOT coming up to speed. Fortunately Lance Campbell was there and knew to change the settings for the humidity on the idle throttle response so I could fly....Perhaps the the auto baro/temp solves this? I was strongly considering the B100F as it does a check of all these environmental factors each start (if I understand correctly). But since I am one deep, now I am three deep...
