Had plans to go out in the car and take of some things. But there has been localized flooding. Went thru some yesterday that came up to the floor pan. A bit scary. So there was now way I was going out today in areas I did not know flooding wise.
So I have been working on the plane today off and on.
Cooked some lunch. Beans and rice in the belly. The garage is going to be a dangerous place to be!
2 shots are when I figured out I had a problem and enlarged the exit holes.
Thees 2 are after I realized I could relocate verticaly the B.C. That helps a bunch. I just reversed the pivot rod. I can adjust things so I split the difference vertical some.
The last is an ideal posted by John on the BHOTR I will play with also.
Ken
