RCU Forums - View Single Post - Need confirm terminal Flightworks Pump
Old 09-20-2014 | 11:25 AM
Justflying1
Hi,
from the image you have provided it's pretty well useless as I can't see the back of it. However it's only a 12v motor and these are extremely easy to wire. If you can clearly identify the positive prong the other prong on the opposite side is the negative. Usually with 12 v motors if you switch the polarity it just puts the motor in reverse.
Ivan
