RCU Forums - View Single Post - Ziroli 1/7 (120") B-25 B scale build
Thread
09-20-2014, 10:37 PM
52
rossmick
continuation of elevator, rudder, stab
Photo 1 - Chiseled out the cut out for the attached tab which will be glued in. Photo 2 - attach tab in place. Photo 3 - First try at extension missing top member.
Photo 4 - completed extension in rough form. Photo 5 - left side extension trial fit.
Photos 6 - 9 shows servo connection to aileron planning using sliding tubes. The layout looks a little close and may not be able to get the 3/4" travel required.
Photo 10 - Aileron center web lay out. Rib spacing above the trim tab are a different spacing than the rest of the rib spacing. Laying out the "D" LE section comes next and the sliding tube interface with the hinge looks like a problem. Going to use the gold Nyrod with the 1/16" wire hinge pin. Also need to layout the hinge locations, looks like there are three of them.
11:10 PM
Reply
Like
rossmick
View Public Profile
Send a private message to rossmick
Find More Posts by rossmick
View iTrader Profile
