Originally Posted by
av8tor1977
There are four long bolts that go in through the bottom of the saw, through the bottom crankcase half of the engine, and into the upper crankcase half. You have to remove those to remove the engine. Be careful, because once you remove those, the whole engine can come apart on you and you might damage a crankshaft seal, or yank the piston right out of the cylinder and damage the piston or ring. If you're careful, you can lift the whole engine out without it coming apart. There will be four metal spacer sleeves in the bottom plastic of the saw housing. Save those, you might need them.
It's been a while; I think you have to remove the muffler, the carburetor AND the carb adapter, and the flywheel to get the engine to slide out after you undo those four long bolts.
AV8TOR
