RCU Forums - View Single Post - Sig Kougar Build
Old 09-22-2014 | 02:25 PM
  #520
jollyroger
Originally Posted by donnyman
Hello
the 3m 77 contact cement works fine and is fast but un-forgiving as it it grabs hold instantly so take time to assure your sheets are in place before laying them down, once together that's it you cannot take them apart. you may want to read up on the technique.
I,ve built and flown all of these birds and they are good flyers but not 3D flyers...................Good luck.
You got that right. The 3M77 really grabs tight. Once its on there it would be the devils own row to hoe to pull the sheeting off. I made sure the sheeting would fit as needed before applying any glue.
