RCU Forums - View Single Post - Electrostik by Electrifly - any good?
Old 09-23-2014 | 07:57 AM
  #40
rcokie
If you epoxy the wing halves together using a single aileron servo, you've created a problem for converting to two-servo ailerons in the future. Look inside the wings from the root and you'll see pre-installed strings for threading the dual servo leads through the wing. Once the wing halves are epoxied together that easy access is gone.
