RCU Forums - View Single Post - Maximum Tamiya Voltage?
Old 09-23-2014 | 09:42 AM
danlrc's Avatar
danlrc
Default Maximum Tamiya Voltage?
Searched forum, but couldn't find definitive answer.
Can I use 7 x 1.2V (8.4V) NiMH's instead of 6 x 1.2v (7.2V) with the Tam electronics?
The obvious easy answer is no, but has anybody done it?
Have really efficient Faulhaber motors, but too slow at nominal 7.2V. The motor max amps are lower than any of the can motors typically used.
Want to use the motors in a Pershing build. Larger pinion is an option, but want to keep the power with higher motor RPM range.
Thanks.
At max charge, 6-pack would close to 9V. The 7-pack would be near 10.5V, only 1.5V higher.
