RCU Forums - View Single Post - Kv-1
Thread: Kv-1
Old 09-24-2014 | 12:38 PM
Rustytrax
Originally Posted by Tanque
I haven't spent a lot of time with this so I'm not certain what the issue is. I thought I'd toss this into the ring to see what happens.
I run, now and again a hybrid ( frankentank? ) KV-1. Mato upper, Asiatam lower with Asiatam road wheels. Mato tracks I believe if I remember correctly I
used Mato's tracks and Mato's sprocket and idler. I used the sprocket as it fit the gearbox shaft; I don't believe I'm using some other sprocket.
The issue is that even in a straight forward run the right hand track will jump the sprocket; not if just when. Even on a hard smooth surface. In reverse
it runs true and never jumps the sprocket even in loose dirt with the track jammed full of dirt- it's clearly not a happy tank but the tracks stay put and
the model toughs it out impressively which is what I was shooting for. I have Mato ( brass) gearboxes with speed reduction to give me power. And that works exactly
as I hoped. Slow crunching power- as long as I don't go out of reverse. In forward after a few feet out it comes.
I think I bench ran this thing with the gearbox running from an external power supply directly and while the sprocket might lose the track momentarily it pops back in;
I think that momentary situation turns permanent while actually running.
The sprockets both appear to run true, I believe the center line of the sprockets are where they should be. I've never modified ( sharpened? ) the sprocket teeth
to see it that has a positive effect.
Just curious if this is a artifact of the KV1's semi dead track ( my Tamiya Pershing rarely does this neither did the first T-34 I ran ) which I keep on the loose side; is there an issue with Mato KV tracks or is it that I need to research this more? Other than this bug the KV-1 is slow, powerful and deliberate just as I intended.
Jerry
If I recall there was an issue with the sprockets and tracks matching. I thought it was resolved though. How long ago did you get them? Although that's not a fact that they are the newest version,
FYI my Tamyia IS2 and Mato tracks don't have this issue. Nor does my PZ4.
Quite possible you have sticking pins that are just tight enough that the track doesn't follow correctly.
