Originally Posted by
DrScoles
I actually read all the instructions and found that its the outer two, good thing I didn't try the middle, says bad things happen.
So, This worked fine on my little 60" electric. I installed it in a jet with a futaba 14 channel rx. The first two channels work, none of the others do. Nor, does the aux. Any ideas? I'm positive I have polarity correct, I tried several combinations, only the first two ports work, the other three and the aux do not.
Dr. Scoles, By any chance do any of your servo extensions have signal boosters in them?? I had some in my plane and had the same problem. After removing them I was able to set it up no problem. I also have a Futaba 14 channel Rx.
Bob
