Bob B, I'm certain its connected properly, the two elevators wouldn't work if it wasn't. Zero chance the polarity is wrong on the leads. Even if I had them wrong, the rudder would physically move. I did not go through the learn process because the ailerons, rudder and aux did not work. I did plug the jumper in and watched it go through the steps, and the rudder did jerk. But it won't allow me to give input. Do I need to reset the gyro since it was already set up in another plane? The directions say no, but that could be it? I have not used the software yet confirmed which version of software/firmware I have. Again, it worked fine in another plane, so doubt that would be a factor either.
Bob#2, There could be boosters in the wires, I did not wire this plane originally, I will look. I'll take a servo and plug it directly into one of the ports and see if that makes a difference.
