Please check your engine. If one of the mounting lugs has a "2.5" stamped on the edge, then you have an S-2500.
If the engine is well-broken-in, you can use fuel that has 10%-12% oil content as long as you're using 100% castor oil.for lubrication. Otherwise run a 12%-15% oil blend.
