RCU Forums - View Single Post - Jetcat Windows Software
Old 10-08-2003 | 01:25 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: Jetcat Windows Software
Well I can weigh in I guess.
First it is my understanding it will not run on Pocket PC, has something to do with math co processor support in Pocket PC. BTW I have tried to get the source code to fix this myself with the DOS version, I still think it would be neat but with my real job I have no time.
Second I do not think you could overlay one flight's data with another, and even if you could I am not sure what that would tell you. What you CAN do however is lay one parameter over another, like throttle position, RPM, EGT, pump voltage, etc. This is great for troubleshooting, especially fuel system or pump problems. You can also monitor all of the turbine states as well.
You could easily lay one flight over another with Excel I guess, if that is what you want. I used to do this all the time with the old software to lay parameters like speed and RPM against one another.
Also not sure if anyone knows this but the new software stores the last 4 seconds of the flight in EEPROM, so you can diagnose 90% of fuel shutdown problems with just the GSU, a major new feature.
