12X Programing Question for Panther
I am in the final steps of setting up my new Airworld Panther and have a programming question regarding the inside flaps (under the fuselage) and outside flaps on the wings. I want to to put each outside flap servo into its own port in the receiver so that I can easily adjust the trims. I am able to put the inside flaps on a "Y" harness and into a single port in the rx. I also want to have the inside flaps deploy when the outside flaps do, using the flap switch on the transmitter. Question is, how can I mix the inside flaps slave to the outside flaps when I am using three ports, versus only two. Any suggestions on set up would be welcome. Additionally, any of you guys flying either the panther or cougar, I'd love to hear about your servo/rx connections for you entire set-up. Thanks guys.
