Right from the manual:
Glow Plug Recommendation
Glow plugs can make a big difference in the performance of your engine.
We recommend using a long-reach, hot heat-range glow plug intended
specifically for high-performance two-stroke engines. Do not use a cold
heat-range plug and do not use glow plugs that use an idle bar. This can lead
to erratic engine runs, difficult tuning and eventual engine wear and failure
Glow Plug:
Thunderbolt # 3 Glow Plug (Product Number 115559)
The Thunderbolt # 3 glow plug is designed to be used in high-performance
engines using fuels containing 10%~30% nitro content and in any
environment. It is a ‘hot’ type of glow plug for easy starting, excellent
transition and incredible top end. The glow plug is also very durable and
Reason: to correct a copy and paste
