RCU Forums - View Single Post - Strato50's M26A1 Pershing
Old 09-28-2014 | 02:12 PM
Strato50's Avatar
Strato50
Wheels arrived and I did a bit of work on the running gear.
The wheel kit from TankArmy is actually pretty nice, better than most other 'metal upgrade' wheel packages Ive tried out. I really liked that they provided all the hardware, and every metal suspension arm was already tapped for the machine screw. I've had terrible nightmares from previous experience with metal suspension arms that broke screw heads or needed to be tapped to M3 screws.
There are really only 2 drawbacks. First the 'rubber' on the wheels is actually a fairly hard plastic. It's molded on separately and is probably removable but I didn't bother. Not that bad of a drawback.
Second there are no metal replacement arms for the 2 forward wheels, the weak spot of the Pershing. I really wish they'd make these and I'll send off an email to suggest it
The bearings in the wheels are nice and snug in their mounts and each wheel spins nicely. Impressed.
Other than that the return rollers are excellent. They all spin freely (no bearings though) and press fit right back into the holes the stock plastics ones came out of. Very nice.
