RCU Forums - View Single Post - Strato50's M26A1 Pershing
Old 09-28-2014 | 02:14 PM
Strato50's Avatar
Strato50
Well Stince is correct and the Pershing during initial test runs is slower than snot on a crisp February morning... motors to be swapped at earliest convenience hehe.
I got to work (...while at work) on the tougher issue being the installation of the recoil / elevation unit.
I made a base plate out of thick aluminum sheet that will be tapped for an M3 bolt to hold it in place.
I formed some thinner aluminum into brackets that the bolts will pass through to secure the plate. I had to move the entire unit backwards a little bit to get proper recoil clearance, and won't get a lot of barrel elevation travel but it will be enough to battle with. This gun with recoil will look good.
(I think my American tankers are compensating for something...)
**CLICK FOR VIDEO!**
