Originally Posted by
siclick33
You need a 3 position switch on the gain channel (or a variable knob). When the travel value of the gain input channel is at zero then the gyro gain is set to zero (i.e. off). Varying the value of the switch endpoints will vary the gain.
How many gyro channels do I need? I thought the only one is the Aux one? So in simple language, I have 5 leads plugged into 5 servo positions on my Rx - two ailerons, two elevators and one rudder. Then I have Aux plugged into a seperate channel - this is the only gyro channel from what I understand. So where do I get a gyro gain channel from?
Jan
