Originally Posted by
Bob_B
Depending on how your electric test plane was setup ie: "y" harnesses could part of the problem you are having. You said you plugged in the jumper and watched the the gyro go through its steps, if you do not move the sticks once in programming mode the gyro will ignore any of those channels that are plugged in. As Wayne suggested check the basic radio setup, then reintroduce the gyro to the install. Here to help, just let me know,
Bob
Thanks Bob, that could be it…. I will try it. Although I think I was putting them in one at a time and testing to see that they worked before the jumper came into play.
Another vote for S-bus! I have three Robbe 2018's, and a few power boxes that are S-bus. The srs has the igryo, but the others don't. Just programmed the nodes for a comp arf P-51 last night, one wire going down the fuse to address five servos is too cool :-)
