Originally Posted by
Bobneal1
What would be really great is if the cortex had a stick priority mode, where the gain would be progressively reduced with more stick input. Like you can do with individual gyros each having its gain channel controlled by the flight channel it is stabilizing
There is no need to reduce gain to maintain control authority. Normally, nothing more than reducing the expo on a channel is needed to give you the feel that you want. The Cortex doesn't fight your inputs the way gyros of old did. For example, the roll rate of the airplane at full stick deflection isn't reduced when the Cortex is enabled, regardless of gain. Still, there are settings that can be tuned with a PC to tailor the "feel" to better suit you if you can't get it quite the way you want by reducing / eliminating expo.
