Originally Posted by
g_mkoch
Dana
What motor/prop combo are you using?
I recently got a Nuance 70 with the A50-12S but wasn't sure on the propeller. I plan on flying with 5s-5000mah
No idea how similar the plane is but I fly my Monolog 70 with an A50-12S, 5s5000mAH, and an APC 15x10. I get about 7.5 minutes with and put about 3000-3500mAH back in after a flight only draining 60-70% so I'm not beating on the packs, plenty of speed and vertical (even though I think my plane is a tad heavy). I've been meaning to try a 16x8 just for comparison as the load should be about the same having no idea if it would be better or worse for performance for pattern.
