Originally Posted by
g_mkoch
Dana
What motor/prop combo are you using?
I recently got a Nuance 70 with the A50-12S but wasn't sure on the propeller. I plan on flying with 5s-5000mah
Same motor in my Natcho'sista only with 4500s. White Xoar PJN 16x12. That said, I am using the Throttle Tech unit with the 5S splitter. If going straight through may want to try an APC 16x10 first to see if that suits the flying conditions and style. The set-up is not so different from a 5S Osiris, for reference.
