Originally Posted by
erans
I made the heat shields, all I need to figure out now is how to glue them in place so they won't fall off...
Eran
Erans,
only the port heat shield is bent, the other side is flat. Check the plans/pictures. Tonight I will check my radio settings and send you a detailed set up. CG has not changed.
JG
