RCU Forums - View Single Post - Super Tigre Availability
Old 10-03-2014 | 09:16 AM
  #34
BillS
Originally Posted by blw
In order to get back to Super Tigers, let me point out that you will go crazy if you try and figure out gasoline pricing.
I owned a Yamaha Franchise during the 70's. At the time average oil consumption was 1 oil to 100 gasoline. Rod bearings were needle roller and crank bearings were ball bearings. Huge amounts of oil were simply unnecessary. Better carbs, needle roller rod bearings and hardened crank pins were probably necessary along with variable ignition timing.
A 125cc would turn in excess of 11,000 RPM. We had transmissions to get the engine on the curve.
