Originally Posted by
gphil
One one these offer a pumped carb while the other uses pressure from exhaust. I want to use a fuel dot and will be incorporating a "T" in the line going to the carb that has a pump. I want to make sure there is a one way valve in carb that will keep from flooding when refueling. I have heard that some have but the smaller cc do not. Let me know if possible. Thanks gphil
You can do that if you want and it will work but it's not the best . The better way to plumb the tank is to just install a third line in the tank with a small clunk so you can drain the tank and run it out to a fuel dot. I run both the 10GX and 15GX and have the tanks plumbed with a third line and after 2 years no leaks and the engines run great.
