RCU Forums - View Single Post - JR Matchbox end point programming
Old 10-04-2014 | 04:34 AM
rhklenke's Avatar
rhklenke
My Feedback: (24)
When you adjust the center, the channel you are adjusting must be in the center. I believe that when it is in the center (or close enough), the LED will be on. When you adjust the endpoints, the channel must be at that endpoint. At this point, the LED should be off.
Don't forget to turn the selector switch to the 0 position before you turn the radio off (and back on) or you'll loose your adjustments...
Bob
