RCU Forums - View Single Post - Evolution 15cc
Thread: Evolution 15cc
Old 10-04-2014 | 06:46 AM
flyinwalenda's Avatar
flyinwalenda
Originally Posted by jester_s1
I run a T in the carb line on my gasser. There is no check valve, and the system works great. I have a filter between the T for the fill line and the carb so that no unfiltered fuel gets to the carb and I also am not putting any debris into the wrong end of the filter. There is no need for a check valve. The gas will flow in the direction that's easiest, and that's to the tank. I understand the concern that some have about putting a T fitting into your main fuel line and the possible leaks that could happen, but I'd argue that a 3 line system is more failure prone that a T setup is. I can put a zip tie on each end of my T fitting and I can inspect it easily. The same can't be said for a 3rd line going through the stopper of my tank. And I can fully defuel my tank if I want to, at least as well as the engine could do it were I just to let it sit and idle until it goes dry. But since my plane is a taidragger, I'd need to run a separate clunk for a 3 line system to get back there to where the last few drops of fuel are. What's the point in that?
Well. one can do whatever they desire. Evolution and Horizon do not recommend using "T" fittings or filler valves ...why? ...because they can leak. If you and others have had good luck then that's fine. I and many others use the third line set-up and like it.
