Do not worry I'm not going to do that to kingtech turbine ,just some old jetcat and I will use to fly in old jet witch is worth not much ,I have least expensive balancer to balance the all thre elements before reassembled + the rear bearing got overheated beacons the oil restrictor su range needle was bent by the previous owner almost 80degre and restrict the oil to much .
