Originally Posted by
superduke1
Mach2 that's a sweet looking model where do you end up locating your battery with your dual rear elevator setup?
It's on the bulkhead just behind the wing tube. I've flown one of my previous revolvers at 6.25" on the cg, so I was hoping to go to 6.5", so I may need to move the battery back. I put the throttle servo in the front because I wanted a short connection to the carb and I didn't think it would make much difference (it's a little hitec 225bb mighty mini) with the two big hitec 645s in the rear.
I am using a simple manual choke system, and I ditched the stock tail wheel for an aeroworks unit. Much, much better. And only about 15 bucks.
